I wanna do an LS vtec build I jus don't know exactly wat I need, can some body help me and list wat I need I wanna throw it n a ef sedan I wanna know if I gotta change both dash and engine harness and wat parts do I need????????????? I know I need a LS block,an LS tranny, a gsr or b16 head,a gsr or b16 engine harness I think,da mounts,and da linkage wat else do I need???????
LS vtec build?????
hasport or avid b series into ef mounts and shift linkage,90-93 integra rear bracket,obd0 to obd1 conversion harness(vtec ready),if you have a ex your front spindles are ok, if not ef si spindles or integra spindles,90-93 integra axles,vtec ecu, tuning,etc. You also might want to upgrade your suspension to handle the extra weight of the swap and I think thats it. You don't have to change your dash harnesstoo low for fat chicks
Originally posted by KrazyAboutHondas View Posthasport or avid b series into ef mounts and shift linkage,90-93 integra rear bracket,obd0 to obd1 conversion harness(vtec ready),if you have a ex your front spindles are ok, if not ef si spindles or integra spindles,90-93 integra axles,vtec ecu, tuning,etc. You also might want to upgrade your suspension to handle the extra weight of the swap and I think thats it. You don't have to change your dash harness
To do it right and stop the whole "LSVTECs are unreliable" bullshit use ARP rodbolts and headstuds. People just slap a VTEC head on a LS block and get pissy when it spins a rod bearing. Golden Eagle and Lightning Motorsports make conversion kits that come with the necessary parts to put the head on the block.Turbo 86' 325i, 20psi of Megasquirt lovin'.
thats the way i did it rebuilt the block you should be good if you follow that guide in the link i posted earlier, g/l with it. my ls/v has been running for a year strong now so i say it is reliable if its done right.S3-R
Stage3-Racing
My old LSVTEC was a rebuilt motor with OEM parts and ARP hardware. It's been running for over a year on 12psi even after I sold the car. But the kid I sold the car to let his friend borrow it or something and the dumbass removed the boost controller and swapped out the wastegate spring for a higher one and toasted rings.Turbo 86' 325i, 20psi of Megasquirt lovin'.
