my boy got a 1.6 non vtec and when u turn the car on it turns ....but it dosent turn on ???its not gettin any spark but the dizzy is brand new never used baught it out of auto zone new what else could it be help out plz!!!
Help me please!!!!?????
Are you sure your not getting spark? Did you try taking a spark plug out while you crank it to see if you have spark? Well, you didnt state if you changed spark plug wires or spark plugs, so check to see if your getting spark and if not, try replacing the spark plugs and the wires as well. And make sure you have the correct firing order. My guess is ether you have a D15b7 or a D16y7.. Let me know what motor you got and I can tell you the firing order for any Dseries motor. And if you dont think your car is getting gas during start up, you can try this. Turn the car to the on postion but dont crank the car. Try to listen for a priming noise coming from your car. That can also be the problem. Good luck and let us know a update.User name is no longer in use! New User name is POGIMOTO!
