questions about milling/shaving head
  • questions about milling/shaving head
    I got a d16y7 civic. I believe the head gasket is going. Im buying oem head gasket, oem head bolts and anything else that I need.
    My question is do I need to mill/shave the head AND block? Or just the head? and how much does that usually run?
    Or I dont need to mill/shave anything? This is a winter beater but i would like It to last me.
    Did the car overheat? And if so how long did it run for? I usually mill the head before head gasket job
    Follow me @bolacan413
    Follow the build @k_insight
      Yea its overheating. Didnt go all the way to "H" tho. Ive noticed my coolants been disappearing. I noticed the rainbow color in my coolant overflow. Radiator looks new and so does the thermostat housing, so im sure the thermostat was replaced. Im sure the previous owner had it overheating too.
      So I guess i could just get head milled?
        Yea man mill it clean it up your best bet if you want a reliable daily
          Thanks. U know how much they usually run for? To mill the head
            Those cars rarely blow head gaskets it tri layer metal. But I think I paid 50$ last time I did one
              Damn dont say that lol. I was hoping its not a cracked head or something. $50 sounds reasonable. Thanks
                U can check if it needs to be resurfaced by putting a str8 edge ruler across it in various angles. See if u can see light threw it or use a feeler gauge. 45$ for a resurface where I'm from . Eastern ct
                Text:8604810204
