Clutch problem
  • Clutch problem
    Thanks in advance for any responses. I changed my clutch about 2 months back. My clutch pedal just recently started having a problem. After I push it in to change gear it doesn't come all the way back up, it leaves maybe like a 1-2 inches. If I put my foot behind the pedal it will come right back up. ONE time i pressed it and it stayed to the floor till I pulled it back up. I have bleeded the master cylinder, I have checked for leaks. Would this be a sign that the master cylinder is starting to go? Thanks again
    either clutch pedal master cylinder or the one mounted on trAnny where u bleed
      Sounds like bad master cylinder. Check inside at the seal of the master and shaft for any leaks.
        I did check the inside there's no leaks what so ever
          This may be a dumb question but when u replaced the clutch were all the components new (pressure plate, clutch disc, throw out bearing and pilot bearing?) if not could be bad pressure plate
            No question is a dumb question, but to answer you yes everything is brand new and I greased everything.
              Check hard lines for any leak or remove the rubber boot on slave cylinder mounted on tranny to see if it's leaking
                Bad master or slave cylinder.
