hey how do i do the timing on a d15 bought car timings all f**ked up
timing help asap
well it could be a wide variety of things is what im saying. what are the symptoms? check timing with a timing light before you get involved with pulling the cover and resetting timing. also do a compression test on it to make sure it has good compression. if it fails compression, then i would go ahead and go a leakdown test to see why.
Originally posted by BurnAll4S4 View Postwell it could be a wide variety of things is what im saying. what are the symptoms? check timing with a timing light before you get involved with pulling the cover and resetting timing. also do a compression test on it to make sure it has good compression. if it fails compression, then i would go ahead and go a leakdown test to see why.
