how do i remove torque converter on d16
  • how do i remove torque converter on d16
    like title states i need help removing torque converter on a d16y7. need this asap
    Google is your friend. I usually use a wrench take out bolts
    Follow me @bolacan413
    Follow the build @k_insight
      While the motor and tranny are together, you take a look under and you'll see 8 or 9 10mm bolts connecting the flex plate and the torque converter together. Pull all those bolts off and ur tranny should come loose. And then pull the converter off.
      ~StayinFRESHSINCE1982~
      SPUNKY MONKEY CREW MEMBER #1
      203 CREW MEMBER #33
        thanks guys already taken off lol. i never fucked with auto shit b4 so i wasnt sure. i just went on a spree removing bolts and i figured it out
