Hi I have a 98 ek hatch and I just changed the clutch and the flywheel and the slave cylinder and the master cylinder and I'm still haveing this problem I bled it good but it still won't go into gear
Car won't go into gear while running
Originally posted by j2a2ndo View PostI already took it out three times and this time I even brought another new clutch
ok this sounds weird but try lifting off clutch pedal a little bit while trying to get into gear ur slave could b pushing to far because of the adjustment at the master i no it sounds weird but worth a shot .. if it goes into gear loosen the adjustment on master
Originally posted by anthonyb5s4 View PostSounds like the pressure plate to meOriginally posted by doitpropa View Postok this sounds weird but try lifting off clutch pedal a little bit while trying to get into gear ur slave could b pushing to far because of the adjustment at the master i no it sounds weird but worth a shot .. if it goes into gear loosen the adjustment on master
Originally posted by j2a2ndoHi I have a 98 ek hatch and I just changed the clutch and the flywheel and the slave cylinder and the master cylinder and I'm still haveing this problem I bled it good but it still won't go into gearhonda sale thread
call/text 203-510-5710
