D16y8 helppppppp
  • #31
    Its not going to be the iacv because that is only used during idle. Its not going to be a head gasket or compression because its intermittent. I'm putting money on a primary o2 sensor, maf sensor or fuel filter cause I've seen these three parts cause the same exact issue you're having
    • #32
      I had the same issue my case was a bad rotor and a cat from helll
      • #33
        Thanks dude I'ma check or replace them sometime this week to see if it goes away thanks for the advice
