Misfire help
  • Misfire help
    Wats up Ctv my boy has a 97 hx ek coupe with a misfire. Changed the plugs wires and cap and rotor and still gettin the misfire, has a cel for iac, cleaned it and it went off. Any ideas wat else can be causing the misfire? Maybe the dizzy? Any info is appreciated. Thanks
    Dead cylinder. Do a compression test and check injectors.
      ^ ×2
      CT-OUTLAWS
        Cleaned injectors gave to try comp test thanks any other suggestions?
          Bad valve or dead cylinder
          JOE BUILT!!!
            do a compression test or swap out the injectores
              did you clean your MAF sensor?
              *S14 Kouki *
                Not sure if serious....
                  ;) shhhh
                  *S14 Kouki *
                    Injectors resistance all the same .013 at 2000 ohms on the meter. Comp test all cylinders good. Not sure wat to do next. Only codes are for misfires. Any suggestions?
                      So injectors are good
                            one injector was bad. Changed it still misfire to one cylinder.no difference on cylinder or running if car when that cylinders spark wire is out.need help we're stuck!
                              Ttt anyone?
