Okay so I was driving and my check engine light started flashing. I turned off my car and restarted it and got a solid check engine light. I pulled the codes and got a misfire on cylinder 3 and a DTC code. The engine runs fine at idle so I cleared the codes and drove the car. No check engine light and everything seemed fine. I keep driving and about 5mins later it starts flashing again but this time the car felt like it was losing power and the engine started to sputters. I can't find out what it could be. By the way my car burns oil and a decent amount of it. I add a quart every two weeks. I'm hoping I just need to replace the plugs due to the burning oil. But if anyone has any ideas or if this is a tale tale sign of a much bigger issue please let me know. The car is my DD and I need it on the road ASAP.
D16y8 help!!!
when my y8 lost compression, it would log misfires at idle, but would be fine at mid RPM. But check compression for sure.
Anytime your CEL flashes like that, its recording active mis-firing. Thats the norm for most all modern cars.
If your getting a flashing CEL and losing power when it happens, then id be looking at plugs, wires, and injectors.
Pulled the code again and got this
P0303 cylinder 3 misfire detected
P1399 manufacturing control. Ignition system or misfire.
Now when I cleared the codes I drive the car no check engine light under normal driving. I put it in 3rd gear and punched it and the car sputters and the cel flashed again. I tried punching it in 1st & 2nd but the car didn't sputter. It seems like this happens when the engine is under heavy load.
I changed the plugs and took the car for a spin. I did the same test and put the car in 3rd at a relatively slow speed and stepped on the gas. The car is running a lot better and so far no cel or misfire. But until I get a chance to take it in the high way and open her up I'm not calling it fixed.
Originally posted by H22SteakSauce View PostDid u move the injector? Compression test?
Originally posted by 203CT View PostI didn't move the injector I just changed the plugs. But after I changed the plugs the car drove perfectly fine. I drive the car to the sandy hook benefit car show and all. Ill try the injector but if it was wouldn't it still have misfired right after I changed the plugs?Follow me on instavtec @steaksauce
Originally posted by H22SteakSauce View Postbut why would it come back? when the cel came on is when u feel it?
