D16 Help
  • D16 Help
    I have a problem I bought a motor while back and now starting to put it in my car i believe is a d16 or d15. when were going to put it in my mechanic said that the crank sensor or something like that is different and I need that piece. What should I do ? The One That I Have does not fit it this whole in the picture
    U need a new mechanic
      You missing the Vtec solnoid and they differ depends if you have a d16y8 or d16z6 look on the front of the block and see what motor code you have
        That also
          its says d16z6
            You need a Vtec Solnoid for that motor then
              LMAO! What mechanic you use? Yourself?
                iight thanks man
                  You need a mechanic and a vtec solenoid.
                    I have a vtec selonoid if u need it =)
                      And a mechanic
                        Lmfao that too....u can have both for $60
                          Lmao
