Hey I bought a 94 civic ex about 4-5 months ago, I have the same idea as you. So far iv done a cold air intake to the right inside the bumper, also headers and down pipe, with a cat delete, stock B pipe and a 2008 civic si muffler. the car sounds nice and is alot more fun to drive than it was stock. but im looking for more. Possible stage 2 cam with upgraded injectors and a dyno tune is what id like to do within the year. but id say with all the stuff i have on the car now iv guestamated to have around 145 hp. I took all the ac out both front and rear bumper supports. Iv installed a 2 inch lowering/ camber kit with a front trac bar. Also drilled and slotted rotors on the front. im looking to get a little more out of the top end by advancing my timing, is this a good idea and if it is how many degrees should i go, because i dont wanna go to far or else it may detonate or just fire wile the intake valve is still open thus loosing power. What are your thoughts?
D16z6 ALL MOTOR BUILD QUESTION
If I were doing this build, I would just set it up to run methanol. Tuning can be dicey but if you know what you are doing, it can make a lot of reliable power. But you can't tune it like a gas powered car. You will just end up blowing it up. Needs huge injectors and big fuel pumps which can be costly, but then again the "cheap, fast, reliable" saying comes into play.4G63T Mirage.
Blk 99' Q45t.
And more.
I am throwing this post together to make is easier for people to get info about getting the most out of a D16 VTEC, NA, while keeping it completely streetable. I am approached every day by people who ask me about my setup, etc, and this will make things easier for sure! The advantages of going...
This thread has tons of information on different single cam vtec builds. No disrespect to ctv, but D-Series forum is way more informative if you are trying to go through with this build, mostly because they only fuck with D-series and wont talk shit on you for rocking the single...they will, however talk shit on you if you post stupid questions or don't use real english. Keep me updated, I am about to start on a N/A z6 build myself.
