looking to turbo my 96 Coupe DX I need suggestions on where I should start it's got 184,000 miles and I want my my turbo to b reliable I just want to know what I should build to hold about 8 to 10 pounds if you can help me out would really be appreciated
looking 2 turbo my single need help!
Well your first problem is your motor has close to 200k lol. Does it burn any oil? Have you compression tested it? I'd say pick up a B20 for cheap from the depot if your not gonna boost a lot and you'll get more out of it than a single
Originally posted by ct tibby View Postehh miles dont mean shit if anything id rather have a motor with more it has gone thru the heat and cool down so many times everything is pretty much setteled now. new head gasket water pump and arp the shit out of everything you will be fine.Instagram @StanceAtlantics , local shoots and event coverage
I'm doing a similar build, what I have done so far is source parts for it.... I would recommend a vitara build... It'll cost less then a eBay turbo kit and you'll have fresh internals.... I'm doing pretty much a budget build (Craigslist built lol)
It's also not about the psi, but more on your power expectations. If you really want a budget build invest heavy on a good tuner..... An eBay turbo kit will suffice for lower power goals (200whp) your looking at 800-1000 for a budget stock internal build. Multiply that by 1.5 if you want a vitara eagle build that will boost reliable power output to 280-350whp
Best of luck
Originally posted by Singlecam View PostI forgot to mention..... Supporting mods cut into cost. You could have a beast of an engine but with a stock clutch or fuel pump its worthless. Kinda like a bodybuilder with huge upper body and chicken legs9-3-12 Legendary IG thatsmrmycocksafloppintoyou
