this happens when im puching my gas just a little bit. if i push harder as you see it doesnt do it. anyone ever have this problem and fixed it?? motor is a 1.5 non v. one friend said its a electrical thing. i have no idea!
U have a vacuum leak. Check all your vacuum lines for any rips.u might need a intake manifold gasket or throttle body gasket or u might have a bad iacv
Lol.no problem. I think u can check your vacuum leak with carb cleaner.if u spray the area and the idle dies down like if it wants to shut off,u have a leak there.
