help with d16z6 swap
  • help with d16z6 swap
    what do i need to swap a d16z6 in a 95 hatch cx
    are you serious? what do you have so far?
    I DO REMOTE STARTS!
      now now nick... lets share info...
      but like he was saying.. what do you have so far?
      ~StayinFRESHSINCE1982~
      SPUNKY MONKEY CREW MEMBER #1
      203 CREW MEMBER #33
        lmao i will tell him everything he needs to know. but i dunno, to be honest it doesnt matter what he has
        he can use any d hydro trans
        d16z6 complete longblock
        p28
        vtec engine harness or modded non vtec harness obd1
        thats whats need for a z6 assuming your car runs stock
        I DO REMOTE STARTS!
          p28
          i second that... since all 92-95 hatches are already pre wired for vtec at the tower.
          203 CREW MEMBER #33
            im pretty sure its 92-93 wired at the tower :confused:
            I DO REMOTE STARTS!
              probably... I wasnt quite sure either, but then again i read from 92-95, i could be wrong... I hardly delt with 92-95 models... I just got back into one this year. once i went ek, I stayed with eks, but now i want the no emissions thing! hahaha
              203 CREW MEMBER #33
                maple story mesos
                For Power levelling Service, we not only level up your account in the limited time, but also send you some Maple Story mesos as gift.
                  if you eg is a dx you have to run the v-tec wires to the ecu, but if its an si, ex, or cx the v-tec is in the wiring harness at the tower. and all you need is a complete d16z6 everithing else should plug right in...
                  axels
                  tranny
                  harness
                  p28
                  complete motor, intake head, dizzi, etc.
                  radiator of course...
                  burger king ronald mcdonald
                  860 crew
                  Pecan Rican #1
                    i think it's only 92 were wired 4 vtec but i'm havin problems w/ my 1 wire 2 to 4 wire 02 conversion it shoud b hooked up rite green to ground white to the 1 wire 02 from stock. black to d w,e the orange nd black on ecu which is wired to my shock tower i'm spliced in up top the other black to the switched power plugs on the driver side what am i doing wrong i tried to sensors all connections are good ne ideas ?
