problems with crx help!
  • problems with crx help!
    my crx needed a new alt so i replaced it ran fine for a few days now all a sudden i go to start my car (push start)it
    cranks but not strong enough dies down quick so i have to put key on acesery and pop it drive down the rhode go to turn my blinker on the tack drops down and up continuesly 0-1 rpms to the beat of my blinker and lights dim ect...is there a short somewhere or wiring problem, bad ecu????? and outher question inside of my crx smells bad like gas while driving or idling i hit gas real quick and it almost whants to die out makes my eyes burn what could that be from thanx
    95 sed/sold
    95 coupe/blew it up
    91 hatchy/current car
    you have some issues with wires in the car crossed or a bad ground. i am going to guess you have a wire tuck?
      Bump gl
      J.R. Built not Bought
        no no wire tuck it just all started happeing tonight??? gas smell and everything els like car runs mad strong and pulls good for a sohc but im bout o just pull this motor and start new wit a bseries swear to god....
        95 sed/sold
        95 coupe/blew it up
          thanx bro need it lol right about now
          95 sed/sold
          95 coupe/blew it up
            bad idea to pull the motor and swap it with out fixing the issue at hand.. you will most likely still have the same issues with the B swap. get threw this prob then swap it.
              bump thanx i will check it out tomm and let u know whats up did you still want that si tranny still got it lmk
              95 sed/sold
              95 coupe/blew it up
                i want the motor more then the trans. but i would like the whole swap...
