HELP! D16z6 into 2000 EK
  • HELP! D16z6 into 2000 EK
    ok just wanna make sure i have everything
    plz add if im missing something
    1.) Car : 2000 Honda Civic DX Hatchback
    2.) Motor: D16z6 out of a 1994 Honda Civic EX
    3.) Wire harness : OBD1 vtec
    i would like to buy a OBD2B to OBD1 ecu jumper harness CASH IN HAND!
    and im i missing anything else?
    Originally posted by nano0222
    ok found out its a obd2b to obd1 ecu jumper harness, am i missing anything else to complete my swap????
      You cant use a obd1 engine harness in a obd2 car. You use the engine harness that goes with the car and the jumper lets you run a obd1 ecu with a obd2 engine harness. Also you need to use a 96-00 driverside/post mount and wire the distributor or buy a jumper
        ok but the hatch is non vtec so i dont wanna hack a non vtec harness, thats why i have a vtec harness. that still wont wrk?
          You will need to get a 99-00 ex harness the obd1 harness wont plug into you car
            If you're going to do this I recommend going through emmisions first if you haven't already because a scanner can't read it when they plug it in if you swap it to OBD1. Also just like adam00 said, you can't use an OBD1 harness you'll need the 99-00 EX harness. Then you can wire the VTEC into the harness by either getting a couple new pins and pinning it into the right spots or cutting the pins off of the z6 harness you have and doing it. I can wire the VTEC correctly if you need me to bro, I've done it to a couple differen't cars including CTB16_LSD's DX hatch when I put his y8 in there.
            Also when you use the OBD2 harness you're going to have to swap over the alternator, injectors, and use an OBD2 VTEC distributor so it will be plug and play.
              ughhh, to much to handle, may consider just buying a y7 swap so i can plug and play
                With a 99-00 ex harness it already has the vtec ran and i dont think a obd2 dizzy will bolt to a z6 head or if it does the timing will be off
                  Actually if the VTEC wire and oil pressure switch wire is in the 99-00 engine harness it should just be plug and play with a VTEC step down harness.
                    Yeah i just remembered lol.
                      Lol in a few words why swap a single for a single just get a obd2 ls
                        Personal experience, i say dont do it, its not worth it, its a headache, i tried to do it once, i sent it to my boy to do the wiring on it, and the hatch still ran like shit.
                        Just save yourself the money and headache. And save up for a bseries.
                        Down Since 09 ...
                        Mugen Inspired DC5
