Oil pan leak helppp!!
  • Oil pan leak helppp!!
    Ok I have replace the oil gasket 2 times on the stock oil pan but it still leaking oil....then I use a y8 oil pan and the same shit idk wtf is going on... My motor is a d16y5 any help? Tnx
    La_Maravilla_2008 is BacK so mamame el bicho
    are you over tightening the bolts and pushing the gasket out?
      Iguess idk leaks from the same spot
        what spot? near the harmonic balancer ? are you using rtv?
          There is little metal rings around the studs u need to remove them they will cause the new oil pan gasket to leak.
          J-ROC TUNING
            it prolly got a hole in the oil pan... or.. remember you gotta torque it criscross...
              I removed them all.....ls94civic rvt? And near the tranny in the u part of the gasket
                Joey it not a hole...
                  rtv= gasket maker
                    Yea it's the right one bro fits perfect but it did the same with. Both oil pans
                      you gotta make sure its super dry and clean
                        Tnx bro I'll give it one more try tomorrow shit is killing me, and just did a tune up .____. Sucks
                          dont use the same gasket over again... get an OEM one, RTV it, and put it on
                            x22
                              if you have acess to a welder. Weld the pan to the block. It wont leak again. Trust me I know from experience.
