conversion help!
  • conversion help!
    What's up guys. Got a eg four door. Ibought it automatic wit a blown headgasket so ised eff it and bought another motor and decided to convert the car to standard. Igot everything already engine tranny axels ecu shift linkage. But everyones telling me ineed an auto to manual tranny mount do finish the conversion. Can someone help me out? Do ineed tht mount? And is there n e thing else ishould know? Any opiniions and anwsers would be appreciated.
    yes u need tha mount or go to the yard and get the 5sp bracket
    use a drill for the tac welds is ez
      U do need a tranny bracket. The auto is different
        Oops that's for a ek. U do need a mount for eg
          x2 auto bracket weld to the frame looks a lil up get the 1 tha look to the side
            Do you kno n e one tht has tht mount? And if ido get tht 5speed bracket idrill out the tack welds and then ihave to weld it back onto my car right?? Will it hold? ?
              yes i use to have my turbo hatch like this and my lsvtec coupe fuk tha mount get tha bracket and weld and call it day
                ebay
                  Okay. The bracket is on the passenger side of the car right? And how does it look? And where do iweld it to on my car?
                    Ican get it off ebay?
                      yes on pass side same way u teck out the auto then weld the 5sp on the same spot is cake bro u should not run into any problems if u teck ur time
                        if u askin about the motor mount yes u can
                          is this 1 on ebay 70usd
                            what's up guys. Got a eg four door. Ibought it automatic wit a blown headgasket so ised eff it and bought another motor and decided to convert the car to standard. Igot everything already engine tranny axels ecu shift linkage. But everyones telling me ineed an auto to manual tranny mount do finish the conversion. Can someone help me out? Do ineed tht mount? And is there n e thing else ishould know? Any opiniions and anwsers would be appreciated.
                            lol
                              They do sell a drop mount off ebay, cheapest way is to cut the bracket out of a 5 speed EG or 94-01 integra. You need to get the bracket off the frame of one of those cars, so drill out the spot welds holding it to the frame then use a air chisel or hammer and chisel to peel it off of the frame. Use the same strategy to peel the old bracket off of your 4 door eg.. And another thing, when u are installing your new mount, dont slap it in the position as you old one, put ur tranny and everything back together and then line up where the mount/bracket belong (the new bracket should sit closer to the radiator on the frame, only by a couple inches)
