Z6 in ek qs??
  • Z6 in ek qs??
    I kno theirs HUNDREDS of threads online about this subject but i feel more comfortable here lol
    So is their anythin else to change besides the knoc sensor, dizzy, mounts?
    ANd how does it run on the heavier chassis?
    Keep nigative comments to your self. If u were born knoing everything lucky you! lol
    I personally would never go through that hassle again.
    not worth it. get a y8 and plug and play.
    Down Since 09 ...
    Mugen Inspired DC5
      z6,y8,y5 y whatever same shit diff book
      Follow me @bolacan413
      Follow the build @k_insight
        Fuxk that stay obd2 don't bust ur ass for nothin
          if u got the money and u stupid stay obd2 if not keep reading on that z6 in ek
            If ur smart and don't wanna hack ur car. Stay obd2
              This^
              Down Since 09 ...
              Mugen Inspired DC5
                there is no hacking involved in putt in a Z6 in a EK and it dont matter what they all say it is proven the y series(y8,y7,y5) motors are all junk they were made with poor oiling issues from the factory they is why the dont make them any more puttin a z6 in there is the best thing you can do for the car.
                you dont need to do much at all the biggest thing to get over is the crank sensor you can do it two ways jump it at the ecu with two clips or you can do it the long way and repplace the oil pump with on from a y series( new not used) and all the crank sensor and gear.. the kock sensor is easy and the dizzy is easy then you can run the y8 intake with all the y8 stuff.. if you google it or look on other site that have alot more and better info you can get a step by step write up...
                try www.d-series.org there are a bunch on there.
                  This^
                    Or slap a z6 crank in ur y series and the problems solved.
                      Pain in the ass to do it right. I have one in my ek but I'll be putting a y8 soon
                        not solved it is the block that is the issue also the oil ports are just poorly made
                          What ports? They all spin rod bearings. How is that not a crank issue? Y cranks have one oil port all other sohcs have 2 from my knowledge. Idk I'm driving right now lol
                            the oil ports threw the block are small and dont flow as much oil at the other block so it kills oil flow and yes the crank has less oil ports but that is half the battle some people can corey parts of the block and oil pump and more oil presser but it is all just a bandaid and helps but not a fix.... that is why the pre 96 motor are best to build
                              Throwing a z6 in a ek is a headache , gotta buy jumper harness & a lot of etc stuff , & at the end your gonna end up with a cel , causee it'd lookinq for the knock sensor & cfk , way too much & not worth it'd . .
                              98Ex DD EJ8 ROADRUNNER
