coolant help!!
  • #16
    But I had the same problem at first my waterpump leaked then I had to change my radiator and thermostat and then it blowing steam out my overflow and ended up being my cap
    • #17
      Originally posted by pizzaboy720 View Post
      Dude buy a new radiator cap the shit is stuck open letting the coolant steam out the overflow
      Will do tomorrow I have a couple caps laying around...
      Originally posted by Drag0n97 View Post
      To pressure test it u gotta get a pressure tester u can go to any parts store and buy one u can rent em from advance auto parts is the car overheating at all or just runnin out of antifreeze?!
      its just running out of anitfreeze
      Originally posted by honda 97 View Post
      X fucking 2
      Same shit happened to me after I changed my waterpump and thermostat
      word so ima change the cap nd see what happens will update everybody tomorrow
      • #18
        Wtf I'm having a similar problem. My Ek hatch is not leaking any antifreeze but it's dumping it out to the reservoir tank or it's using some coolant at times .I have my fan on at all times because if I leave the fan connected normal,the coolant will come out the reservoir tank and cause it to overheat.with the fan on at all times,it will not overheat but I get a misfire on start up and cel for misfire.I'm thinking it's either my cap,thermostat,or head gasket.at this point I have no clue and it's 2 dam cold to be fucking around with anything.
        Originally posted by knuckk
        • #19
          Damn
          • #20
            ^^damn bro it is too cold...but this morning I put a little more anitfreeze poured a tiny bit into the radiator and now after work the heat was working better...Hondas are weird lol
            • #21
              Originally posted by jdmdikk View Post
              wtf i'm having a similar problem. My ek hatch is not leaking any antifreeze but it's dumping it out to the reservoir tank or it's using some coolant at times .i have my fan on at all times because if i leave the fan connected normal,the coolant will come out the reservoir tank and cause it to overheat.with the fan on at all times,it will not overheat but i get a misfire on start up and cel for misfire.i'm thinking it's either my cap,thermostat,or head gasket.at this point i have no clue and it's 2 dam cold to be fucking around with anything.
              cap!!!!!!!
              • #22
                ^^ lol
