Helpppp!!!
  • Helpppp!!!
    K so I got a 97 ek coupe ex ,one day I was drivin it and the battery just died outta nowhere so I charge it,put it back on ,drove it again it lasted me like 10 min,(battery was fully charged) battery died again,so I got a brand new alternator and alternator belt,installed it wit another fully charged battery,lasted me 10 min,shyt died again,idk do I need a brand new battery or wat,idk I checked all fuses 2 wat could it be?
    ^^ usually when you charge the battery , autozone can tell you if the battery is good or not .
    98Ex DD EJ8 ROADRUNNER
      Prolly bad battey
        Is your check engine light on? is your speedo not working?
          Even if it was the battery the alt should keep it running and it shouldn't die. Maybe you put in a bad alt. Test it and your battery too
            Please answer my questions because i might be able to help you
              This happen to me wit my Orange hatchi bro, my battery kept dieing, bought a new 1 that died to, come to find out the alternator had a bad wire conection. Rewired it, and no more problem.
                ^ def check all connections on alt and battery !!!
                  I had this issue...bad engine harness...it shorted on the bracket that connects the intake mani to the block.
                    Oh damn... I would've been at the local gas station buying gas n setting that bitch on fire
                    Gotta b something stupid tho like always
                    Follow Me On Instagram
                    Jdmkid618
                      i had the same problem steaksauce. there is a honda service bulletin about it
                        Yea I dont remember if I had a cel but I know my speedo didn't work...my harness def got fried tho...nice n crispy I had to re wire half of it lol
                          damn that stinks bro. all i had to do was tape up the exposed wire and it was straight. the speedo doesnt work because the speedo and alternator are on the same fuse #15
                            Speedometer doesnt work
                              I think the alternator is not gettin connection
