my timing belt keeps tryin to slip off
  • my timing belt keeps tryin to slip off
    yea just finished my mini me vtec project cars in timing and everything but the timing belt keeps tryin to slip off
    Either the belt is toooo big, or you can Make sure the tensioner is tight. Use a pry bar and push on the tensioner before tightening it so you get good belt tension ... D and B seires tensioners arent like GM belt tensioners where u let them go and they give it automatic spring tension. Use a pry bar and hold pressure on the tensioner while u tighten. The belt should be able to turn a little bit by hand but not toooo tigh. You will burn out your water pump and tensioner if too tight!
      i think the book says there should b a 1/4 inch mayb off like play/slack if that helps
        when i turn on the car the belt looks straight but when i turn it off u can see it slippin off a lil
          Nick, I have never tightened a timing belt like that.. From what I remember you install the belt tighten the tensioner rotate the motor 360. Then when its back at TDC you loosen the tensioner. rotate 180 then torque it down. Again dont quote me but thats along the lines
          I DO REMOTE STARTS!
            your going to need a vx timing belt because its a 1.5 vtec and ur block is a 1.5 and that belt is smaller from a 1.6 i was doing it but i went to a 1.6 fully
            mr.snuggles to you bitch
              make sure you have the the belt washer on it goes after the belt and before the pulley on the crank
                i got a 1.6 belt on it someone told me it could be the tensioner but the belt stayz tight the tentioner tightins the belt i have is from the 93 ex d16z6 ..so ur sayin i would need a 93 civic vx belt
                  No nick ur100 % right but see when you work at a garage for a couple of years u start tto learn some small tricks but yea its all good
                    yes u will need it 1.5 vx vtec e belt
                      Cheap Baume
                      Cheap Baume & Mercier watches Wholesale
                      Cheap hotdeal watches - Baume & Mercier watches
                      All of our Hotdeal watches are shipped via EMS to worldwide. Normally it takes 3days to prepare the Luxury watches you ordered and 5-10days to transmit depending on the different destination.We pay for the free shipping cost for total quantity over 20 pcs. The EMS tracking NO. will be sent by email when an order is shipped from our warehouse. No more other charges from watchesvip.com such as the tax. If you have any other questions please check our other pages or feel free to email us by sales@watchesvip.com.
                      We guarantee 100% high quality of Wholesale Baume & Mercier watches. You will get the best China Luxury watches by lowest price. When you decide to order these replica watches; send us the list; We will deliver within 3 days.
                      Offer of Baume & Mercier watches . These jewelry watches are popular in markets all over the world. We guarantee high quality; and favorable price may we offer. Best service you will receive from us. We patiently settle all problems that clients come up with. Once you order our hotdeal watches; you will receive these Hotdeal watches very soon because we won't delay to deliver for you.
                      The Same Baume & Mercier watches Series:
                      Cheap Hotdeal watches - Luxury watches - Jewelry watches - Baume & Mercier watches Wholesale
