Ok so my boys ek starts up a little rough at first...drives perfectly fine..very smooth etc...then once its turned off, it just cranks and takes a few moments to start...sometimes up to 2mins..not continuous, don't want to mess up the starter....fuel pump primes..doubt its the main relay..my guess is the distributor is starting to go and its not getting good spark, spark plugs, cables...dizzy cap and rotor were recently changed...car has plenty of gas, starter is working fine, alt is charging battery, battery itself is good, holds a charge etc......any ideas?
d16 has a rough start....
Originally posted by crzycivic93 View Posttry a main relay.. fuk it.Originally posted by SeanJDMJohn View PostHonestly my boy had the same problem it was the main relay it would start fine nd if he stopped at a gas station nd turned it off sometimes it wouldn't start right upWTB Work, Mugen, or Volk wheels
Someone will say yes but I have a bunch of spares nd the 96-2k one is taller but the plug will fit a 92-95 don't kno if it makes a diff but I like to do stuff with the correct corresponding componentsOriginally posted by Deathwish203Im on welfare...can i get a better deal???where u located
Originally posted by SeanJDMJohn View PostSomeone will say yes but I have a bunch of spares nd the 96-2k one is taller but the plug will fit a 92-95 don't kno if it makes a diff but I like to do stuff with the correct corresponding componentsWTB Work, Mugen, or Volk wheels
