D 16 still won't start
  • D 16 still won't start
    I put new fuel pump new main relay battery charged distributor has spark and the plugs are fine my car still will not start pls help
    Originally posted by JayZeeGee View Post
    ^x2. if the car runs with starting fluid being sprayed in it then its a fuel problem. make sure u have power at the pump when you switch the key to on.if no power to fuel pump check fuel pump electrical circuit.
    fuel pump has power? make sure u have pressure at the fuel rail. if no pressure at rail bad fuel pump or restricted fuel filter.
    pressure at the rail? make sure the injectors are pulsing with a noid light. if no injector pulse bad crank sensor or ecu.
    am i forgetting anything guys? its been a long day...
    BACK FROM THE DEAD
    FUNCTION > FORM
      Could my timing be off
        Check ur grounds
        Follow Me On Instagram
        Jdmkid618
          Aight
            I do recall seeing ground that was loose but didn't know if it made a big deal
