I have 97 civic hatch dx and it's idling from 2000 to almost 3000 non stop I cleaned the sensors and the throttle body but it got even worse than it was....any ideas on what it could be
Idle problem
yeh well fist is there a cel? if so find out wut the code its throwing cus that would be your problem....a code should come on for any of the sensors that these guys mentioned..including tps...iac...and map sensor. now if you dont have a cel then in all likely hood its the cold start valve thats sits under the throttle body opening...the reason for this is that there is coolant flowing through it but if you notice there are no electrical connections to it! it connects directly to the iac so if its clogged or broken it will slow the flow to the iac and make it do wut its doing without throwing a code....you can just replace it and this part is the same on singles and duals u just have to switch the lil cap where the hose connects....or if you cant get one try takin it off unscrew the end where its flat with two tiny screws and you will see that its spring loaded...if the spring is all the way out then u found the problem..take a screw driver and tighten the spring back down....try these two things and hit me in the mornin...lol doctor efadict does it again!!! lmao
