i had this prob i had some messed up wires nd that fried my dist so had to get a new one of those check ur alt they check it for free everywhere if it aint there then check all ur shit starter etc does the car turn all the way off when u try to turn it ON like the battery is dead?
94 civic won't start
Originally posted by ct tibby View Postlol wtf? am i the only one reading what he said? its obv a fuel issue. if he can start it with fluid he has spark.
fuel pump has power? make sure u have pressure at the fuel rail. if no pressure at rail bad fuel pump or restricted fuel filter.
pressure at the rail? make sure the injectors are pulsing with a noid light. if no injector pulse bad crank sensor or ecu.
am i forgetting anything guys? its been a long day...BACK FROM THE DEAD
FUNCTION > FORM
It could be almost anything start with the basics. Pull out your spark plugs leave em on top of the motor look see if the plugs are sparking. Make sure the spark isint going throu the wire and grounding on the motor. Do you have a cel code if so find out what it is. Have you battery tested and altenator at auto zone or something its free at some autoparts stores check to make sure the connections are tight on battery Check your 2 main grounds on the motor make sure there tight. Check the ecu ground wire its on your thermostat housing. Look around for broken or loose cinnectors. poat on hear if you hVe foundanything. when you turn your key to on in the main relay and sould hear the hum of the fuel pump in the back you can and unscrew the top of your
