Z6 in ek??
  • Z6 in ek??
    So I swap a z6 into a ek did all the other run around bs car crank all power everywhere fuelpump goes on now my issuie is I'm getting power to the dizzybut it's not putting it out I recheck all my ground and fuses and I used a power prob to make sure that power was goin thro I would just like a few ideas to try cuz I completely ran out also did relays Also.
    BFAM-racing#2
    BFAM-racing#2
      BFAM-racing#2
        Coil or ignitior, if it has power at the
        Coil one of them is bad. Also check the wires, do u still have my 4dr/ want to sell it lol
          Lol that's actually what I'm swapon it in
          BFAM-racing#2
            did you do the crank sensor bypass trick?
              ^^ YEa gotta do the crank sensor bypass trick cus obd1 motors doesnt have the crank sensor plug . . .same as the knock sensor too . .
              98Ex DD EJ8 ROADRUNNER
                you have to match the cam gear to the ecu. z6 gear with p28 and y8 cam gear for the obd2 ecu. the key hole pin on the gears are off by 4.5 degrees.
                  ^^ it will still run and you should have to do that when you older motor in the newer car you can make up for that with the adjustmanet on the dizzy.
                    ignition timing (distributor)and base timing is two different things (timing belt).
                      if you say so bud i have done it a few time curently have a 1997 civic coupe with a crx HF motor in it stock timein belt and gears onther then the crank bypass no mods to put it in no timeing belt mods no swap passed emsiion CEL free and runs flawless.
                      to the the thred starter if you did not do the bypass do it and she sould run.
                        i got a dizzy pm me
