Wen the cars runin I put new altinator and battery its dims and flashes withe the lights on or off dnt matter please help?
ek batt light help
i would check all ground wires make sure there contact points are clean, clean the surface area with a 2000 grit sandpaper..... and clean all terminals wouldnt hurt to use at that point die electric grease ..... seeeing were coming into fall and winter to keep all the nasty shit out of the cleaned surface ......EM1-860-CTmember..1...
J-SWAPS ....860-457-8335
there's a known problem with EK's from what I remember with something called the ELD (electronic load detector). I know there's a big thread on H-T about it and fixing the issue, poke around and see if you can find it, that's what it sounds like the problem could be.
edit- im pretty sure this is the thread
