White smoke!?!?!?!?!?! maldita sea!
  • White smoke!?!?!?!?!?! maldita sea!
    D16Y7... stock no mods to engine... header back exhaust & intake only...
    New plugs...New oil & filter...
    :mad:So, I've been reading around.... Seems that I might have a blown headgasket... A little history... I had my car sitting for about 5 months...
    when I fixed the reason why I had iot sitting I noticed my idle was going up and down like if it was revving. So, I cleaned out my IACV and it
    fixed the up and down but now it idles high. Yesterday, I started it up to keep it fresh and I noticed a lot of white smoke coming out of my exhaust.
    This never happened before so now I'm worried I have a blown head gasket. Just so you know while the car sat all of the coolant evaporated and while I was trying to fix my idle problem I also tried to bleed the coolant. I did see a few bubbles. My question is how do I know for a fact, 100%, without a doubt that my head gasket is shot?
    come on someone gotta know something about blown headgaskets....
      does the white smoke goes away once the car warms up ?
      its cold out that may just be vapor
        no it stays after car is warm...but it does not smell like coolant... it wasn't cold the day i started it up when it started smoking...
          if u got a blown head gasket ..itll b burnin all your anitfreeze ... so check your coolant level
          *S14 Kouki *
            gotcha... will check after work...
              update...
              so i worked on it a little trying to figure out if in fact my headgasket went or not...
              white smoke lasted a couple days... checked coolant and it seems fine I did have to put a little in and I do mean just a little... no more smoke at all... i need to bleed my coolant though there's air in thier i think that what my idle issues are all about...
              so it looks like i don't have a blown head gasket since the car no longer blows white smoke... who knows... anyway thanks to those who offered some help and/or any suiggestions...
                :rolleyes:
                  If u have a bad headgasket check ur oil if it looks like chocolate milk then u have a bad headgasket
                  WILSON BUILT
                    that's the 1st thing I did... I was told it would look like a milkshake under the valve cover. thanks.
