Need Help!
  • Need Help!
    Hey i have a 95 Civic Ex (5 speed) and today while i was drivin it would grind 2nd at times and then would be a pain to go into 3rd at points. Also wouldnt even go into 1st gear. Id have to like really push the shifter into 1st and it would grind. What do you guys think it could be? Tranny? Shift Linkage? I dont even be beating on the car at all. Shift 2500-3000 RPM all the time. Help would be appreciated. Bump if viewed to get some more opinions. Thanks
    Maybe the clutch is going
    ~StayinFRESHSINCE1982~
    SPUNKY MONKEY CREW MEMBER #1
    203 CREW MEMBER #33
      thats what i think too.
        Def is the clutch
        Follow Me On Instagram
        Jdmkid618
          Bump. U guys sure?
            It happened to my boy n my cousin... shit did the same thing ur explaining n finally broke n didn't take no gears at all... they had to shut the car off, put it in gear n turn it on...
            Jdmkid618
              Damn this shit sucks. Thanks on the info bro
                Slave cylinder, check it....bleed it & shuld go back to normal, same happen to me last week
                  I agree with eg luny... check wha he said b4 u go spending money on a clutch/tranny
                  Jdmkid618
