axle nut!
  • axle nut!
    im trying to do my girls clutch in her fuckin coupe and i have no luck at all with getting the axle nut off i torched the shit out of it i been spraying it with pb blaster + wd40 i have alredy broken 3 craftsman breaker bars i have been using a impact gun too and i can not get the fuckin shit off i have never delt with axle nuts like this before! help plz
    bring it to midas or somewhere and have em use their impact gun to break em loose. Then tighten em with a breaker bar, drive it home and start over. I had the same problem I ended up taking off the whole spindle / axle as 1 piece and bring it to meineke and having them loosen it.
      Need a real impact I got a snapon battery unit they has not failed to remove a axle nut for me even ones in the mud at the bone yard
        lol go get a brand new breaker bar from sears, put a punch in the rotor to stop it from turning then put the break bar on and put the jacks extended pipe all the way over the breaker bar and stand on it moving up and down.. this has never failed me and ls vtec tighten the fuckkk out of my old coupes nut took atleast 1h 30m
          I'm a beast. Sorry.
            I'm a beast. Sorry.
            understandable sometimes u just dont know your own strength with the 3/8 driver happens all the time
              I hate when they r a bitch.. Good thing I got a compressor now
                I used one of these to tighten it.
                  i new it, but the LCA bolts are far worse then these my bushings are spinning fml
                    lmao . and ya i jus took the whole fuckin spindal out wat a pain in the fuckin ass
                      i have goten 3 replacments alredy for breaker bars at sears within 24 hours lol
                        everything that everyone up here said works good but if all else fails....use a good ole fashion chisel and hammr or even a drill with a nice bit then just chip the old nut off peice by peice...your changin the axel anyway so u dont have to worry about the thread...just make sure to go at it with the wheel off..lol!
                          this will also work great to take it off with w pipe on the handle!! its so short and solid the only thing that could possibly break is the gear inside...now if that breaks on this type of ratchet..WOW!!
                              my boy!
                              Originally posted by LS/Vtec
                              why yu mad doe
