d16 turbo ?s
  • d16 turbo ?s
    untill next spring im not gonna build the bottom end...and im going to run only like 5 or 6 psi through the winter i just want to no what i would need to do for the low psi turbo build....i no about all the piping and turbo/intercooler...and blowoff valve.....but do i need to do anything to the fuel pump just to run 5 or 6 psi? and will the clutch/ tranny be able to handle the power wich most likely is only going to be around 160? untill i do the bottom end build in the spring......also what size injectors should i buy
    d-series.org <<< all the answers ull need
    203CARTEL_John$
      you cannot make him drink
      You can take a horse to the water but you cannot make him drink.Come and buy age of conan gold, AoC Gold, AoC Power Leveling and AoC Accounts here, aoc gold the easiest and safest way to enjoy a wonderful Age of Conan life! aoc power leveling, aoc power leveling, age of conan power leveling..
        i have rc 440s for sale, good for that amount of boost. i am runing 16lbs on my d16 and i upgraded to rc 750s. car for sale
          you gotta run 750's with ur build but for like 5-6 lbs he could use like 310's thats wut im using for my break in process.
          PhotobucketPhotobucket
          GBG
            the size of the injectors you run doesn't translate to how much boost you want to run. it's about the horsepower output. 310's are good up to around 180 hp at the wheels. But if you are saying you want to build your bottom end in the future i would get a set of 550's. they are good for well over 300 hp.
              also, what size turbo will you be running?
