dude i just did a min me swap to my 94 civic hatch and i put a d16z6 head on the d15b8 block and i did everything you are sappost to so im confused can anyone help me why my car wont start what do i need to get it srarted and please need help fast
cant get my mini me swap to start need help
Originally posted by jdmjunkie9753Towards the front of the car advances it and towards the windshield retards it. Also check your firing order (what spark plug wires go to which cylinders from which spots on the distributor).Originally posted by jdmjunkie9753No you shouldn't need an aftermarket cam gear, as long as you put the timing belt on right you should be fine. Just go on google and look up D16Z6 firing order and it will give you a diagram. If none of that works I would open up the distributor and check the cap and rotor because its possible those need to be replaced too (cheap fix).
