where is crankshaft speed fluctuation sensor located
  • where is crankshaft speed fluctuation sensor located
    hey does anyone know exactly where the crankshaft speed fluctuation sensor is on a 96 ex d16y8 the damn cel light went off and thats the code that it gave me so apparently its intermitant not sure if i need a new one so i gotta check that out
    single cam ham
    never heard of it. only thing close i can think of would be crank position sensor...
      CKF is on the lower timing gear. in the timing cover. the wire comes out near the alternator
      (860) and beyond
      #DavesTuning 8608050968
        x2
        2+2= 4Dr H22
          x3
          Follow me @bolacan413
          Follow the build @k_insight
            gotta get to this now lol thanks
            single cam ham
              test the wires there is a issues with some cars the harness has a intermet short. but not hard to change pull the belts off alt.p/s a/c and then pull the crank pulley and there it is. i have a few used ones if needed
                also if you google it you can go on FFsquad and there is a write up on how to bypass it so you dont have to do all the work.
                  ok thanks lol i might just have to wait for the warmer weather lol sounds like a lil bit of a project
                  single cam ham
                    I got one if you need it
                    J-ROC TUNING
                      What up
                        ok ill let ya know if i do need one
                        single cam ham
                          google it there is a bypass trick it is about 2 min fix at the ecu that will cost you 5 bucks turn the light off
                            oh sweet ima check that out what did you put in for key words
                            single cam ham
