2000 civc overheating
  • 2000 civc overheating
    ok heres the deal so i fixed the over heating problem, it had a leak in the thermostat, now i realized that the fans are not coming on at all...... i checked it with two wires to the batery and it came on. i checked it with the relay from my car nothing but the car doesnt over heat. but it smokes a little from the radiator i need help asap! i dont want the radiator to overheat and blow up
    is the fan turning on?
    The Power of Dreams
      if its overheating at a stop check to see if fan is kicking on. if its not check fuse under hood box. if its overheating when ur driving it and the coolant is topd off and you did the thermo then u have headgasket issues.
        Originally posted by rican246
        My girl has a 2000 civic ex auto and it keeps over heating I put a new thermostat yesterday it has antifreeze in it but I don't know what's wrong any ideas? It was over heating before and it would take about 20 mins of driving for the heat inside the car to get warm and after we did the thermostat it was better and got back to normal but it overheated again today Please give me some input
        Did you check if the mixture was right?
          Did you install the thermos correctly? Did you bleed the coolant system of any air?
            I did notice that the when the car is finally at normal temp the fan wasn't spinning?? Is that normal?
              check your relay under the hood for the fan ...
              The Power of Dreams
                ok so i found that the theromstat houseing is leaking and the pipe going from the water pump is leaking how do i remove that whole assembly is the water pump, pipe, and thermostat houseing 3 pieces?
                  Yea 3 seperate piece. Remove the thermostat housing. 2 Long 10mm bolts hold it on...Not the coolant hose neck. Then you can pull the tube out. It slides out towards the pass side of the car. You may have to go in by the alternator and pry/pop it out with a flat head.
                    Check my thread kid ill trade you my del sol and take your car as is
                      Nah man it's my girls automatic coupe I know it don't have a big problem I just never had this problem before but I got everything off it'll be fixed by today
                        It worked thanks
                          someone help me out i need it!!
                            anyone?????????????????
                              Theres air in your coolant system ..or u could also have a bad thermostat
                              *S14 Kouki *
