running 3 cylinders only
  • running 3 cylinders only
    Don't know if its the motor it's self or the fucking hack job wiring some mechanic did.....if anyone knows what cud be help it would be greatly appreciated
    see if ur injector is working properly
    Follow me @bolacan413
    Follow the build @k_insight
      deff not the wireing cause the last motor ran fine.. u prolly got a dudd .. change the spark plugs and see
      D and G auto member #5
        check your antifreeze just had the same problem with my hatch turned out to be the headgasket was such a little amount was getting no smoke but was enough to stop cylinder from sparking
        !!!!!ThE GoOd DiE YoUnG!!!!!
          gas saver ftw
            check the cylinder for spark... then check if it has compression ,,, if both of those are good check to see if the injector is throwing fuel,,,
              it can be a couple of things like a tight valve or wire or injector or spark plug
                Injectors are working, gonna change the spark plugs tomorrow
                  Check the injectors with a injector light, check to make sure the plug wires have contact with the plug, do a compression test on the cylinder, check coolant for bad head gasket. Theres so many different things you can do to troubleshoot.
                    Yea. Imma do the spark check in the morning then change the spark plugs, imma have to find sumone who has the injector light and compression tool also
