so i heard the z6 oil pump has better flow can it be put on a y8 im hoping it will help with the notorious rod bearing problems the y's have
z6 oil pump into a y8?
Lol I can't wait to see this happen lol tell me how you Gooing to check you oil ?????
Y8 don't have dip Stick on the block it built in to the oil pump part of the y8 bearing issues is the crank pulley and part the oil pump you can buy a new oil pump y8 and be.good for a wile you can also buy a ported oil pump for better flow or you can take the oil pump you have port it right and shim the pressed spring and raise the oil presser that why Google it or look on Honda tech or d-series.org and there are many write up how to do itRIP Nick
Originally posted by ctgoldhatch View Postlol i can't wait to see this happen lol tell me how you gooing to check you oil ?????
Y8 don't have dip stick on the block it built in to the oil pump part of the y8 bearing issues is the crank pulley and part the oil pump you can buy a new oil pump y8 and be.good for a wile you can also buy a ported oil pump for better flow or you can take the oil pump you have port it right and shim the pressed spring and raise the oil presser that why google it or look on honda tech or d-series.org and there are many write up how to do itWILSON BUILT
