anyone got any good ideas for a good all motor build fer a single?
a little advice
Originally posted by 91efhatch View Postuh id go y7 or z6 you could build a nice one for not to much or f22 series but depends on what your dropping it into i know i need to cut and weld to drop an f into my ef so i guess it also depends on how much work your willing to do
if your really going all motor go with as many oem parts as you can,,id use jdm zc pistons also found in the d16a1,,put them in a z6,get arp rod bolts (having the rods balanced at this time would be an exellent idea) ,new rings bearings etc..and FULLY build the hell out of the valvetrain, 70 mm tb and a huge intake manifold,,stage 2 cam,port match intake mani to head,,and put a tri-y header on it with some dsm 450's,,have it dyno tuned by dave and youll make some nasty power for a d16 if thats what you r looking for,, thats how i would build a NA d seriestheres no replacment for boost:)
