d16y7 help
  • d16y7 help
    have a 96 4door car runs fine for a while then when slowing down car turns off will start back up but as soon as i start slowing down n stop it turns off
    had i codes b4 misfire in cylinder 2 n 4 and random misfiring
    car has new dizzy cap n rotor cables and plugs just changed the timing belt and still has same ploblems but not it doesnt show any codes need help asap
    Timing sounds like it is off.or the dizzy starting to die
      dizzy is new so is the timing belt might have to take it sumwhere to see if timing is off
        If.the.timing.is off it.will try to make up to it and stall because it can self adjust
