z6 in ek
  • z6 in ek
    I just bought a z6 and put my y8 intake mani, dizzy, alternator, and engine mount... the z6 has no crank position sensor.. i've googled it and they said that you dont need it.. do i nee obd1 ecu? or will it fire up with the obd2?
    Originally posted by LS/Vtec
    why yu mad doe
    obd1 jumper harness will work fine u wont have a cel for the crank
    J-ROC TUNING
      No jumper harness needed there is a very easy fix for that
        Thanks guys
        why yu mad doe
          i used a jumper harness
          *S14 Kouki *
            If you use a jumper harness you won't pass emissions
