Ok so my y8 has a spun bearing i was just wondering could i just change the bearings or do i have to get the crank re surface 2
spun bearing fix help!!
the prob is you can changer the bering and or the crank and that is not always the issue the d16y8 has known oiling issues so most likely it will happen again. the oil pump is weak in them and the oil ports are small and shitty. get your self a z6 and do the crank sensor jumper and run thatRIP Nick
