Ecu not getting any power to it not reading any code sensors check engine light.......only showing battery light what could this be????
Help Ecu Problem!!!
you are missin or have a bad ground from the motor to the chassi. you need to run one or two ground wires from the motor to the chassi or right to the neg on the battery. your ECU ground is on the motor harness and grounded to the theromostat housing and it not being ground to the chassie or battery it wont work.RIP Nick
I got to 2 grounds I kno one of the are from the chassis to the battery dnt know bout the other one ill check that one tomorrow....if it's not one of those what else you think it could be....if anyone wants to try to come help pm me and ill let them know what's good with if they could get it good to go
