Making yo' vtak pop fo reelzzzzz!
  • Making yo' vtak pop fo reelzzzzz!
    Here, let's stop the madness and sticky this shit! No rigging your vtec to a momentary switch or a shift light.
    OBD1
    Hook up the solinoid like so: Wire to a4 (green) and ground (black)
    Hook up the oil pressure sensor like so: Wire to d6
    If you don't have the harness go buy some wire from Napa/Autozome/Advanced Auto Parts/Home Depot. While you are at it get some shrink wrap, solder and soldering iron and do it rite. Otherwise when the barrel connector get's a bad connection your vtec will start to fuck up.
    HOW TO SOLDER AND NOT SUCK:
    Don't forget to put the shrink wrap on before you solder...electrical tape works but longevity is not quite as good.
    OBD 2
    solinoid to A8 and ground
    oil pressure sensor to A15
    My work: Flikr.
    nice
    USMC
      bump for good stuff
        sticky ...for sure
        CGP CL9
        1993 EH3
          You should also post the CKF bypass trick for the people trying to run jdm engines with a usdm ecu
            I don't know the bypass trick mang
            My work: Flikr.
