help on a d16z6 stock build
  • help on a d16z6 stock build
    i am in need on some info here what i am doing is a basically new block i am going to rebuild new crank 50mm new stock pistons and rings acl bearings and oil pump new as well but for head wise i am going to shave the d16z6 head port and polish it and rebuilt it redo the valves but for cam wise what cams should i go with crowers or zex or skunk2 idk any info would be nice
    mr.snuggles to you bitch
    why put money into a single when ou can do a stock block ls/vtec for cheaper...
      most people that use zex is for turbo so if i waer you to get some power just go turbo with Vitara pistons and some H rods you will feel some real power i seen people pushin from 250HP to 350HP depending on the turbo.
      becuase its JDM!! It has to be better!
        agreed
        ~StayinFRESHSINCE1982~
        SPUNKY MONKEY CREW MEMBER #1
        203 CREW MEMBER #33
          I want to learn how to put a stock block together and I don't have money to do or get ls vtec I lost my job I had 3 back suregrys so its hard at this moment trying to do something to keep me busy plus the kit with everything I listed brand new is 284 brand new so imma try it out and see
            I will this summer when I get a job or heal up from 3 back suregrys if not heal try to fight the pain and get a banging job to get me those things
              lsv is over rated! D for the win!
              My work: Flikr.
                yessir it is
                  i deff will recomend to build dat d16 i got one in ma hatch doing high 11s but no comment!!..
                  www.solavei.com/lopez2333
