obd0 to obd1 swap help
  • obd0 to obd1 swap help
    Aight so i got a EF hatch with a stock obd0 harness & i'm tryin to put the obd1 harness out of an EG hatch i bought but i was told i need to swap the harness for the electronic doors as well What do i need to do to swap to obd1 if i have the whole harness can i just drop it on & go?
    what kind of harness are you talking about i have both obd0 to obd1 jumper harnesses.. if you have a stock incar harness then you have to wire it up to obd1 or get the jumper harness i have both incar harness and motor harness plug and play and vtec will work i had it on my ef 4dr
    D and G auto member #5
      i looked away from the jumpers cuz the motor harness in the hatch is conected to a carburator type & i'm lookin more for the newer fuel injector thats why i took the harnes out the eg along witht the intake and dizzy
        i know that my ef is the same thats why i have the jumper harness it turns ur car from dpfi to mpfi with out cuting or having someone rig it up its clean and easy to install and take off when needed i got both from rywire.com and im selling them if you want it to work then u need these or have someone rig it up
          PM me with pics & price plz
            Get that rywire shit, or search. if you don't want to spend the money you can do it yourself but if you have the money get the rywire jumpers. Replace your injector harness, install jumper harnesses, and hook up the p whatever for your engine and you are set. Don't forget to run wires for vtec (if you are putting a vtec engine in).
            My work: Flikr.
              Or just call me and we can get it poppin. You will still need a jumper harness.
              (860) and beyond
              #DavesTuning 8608050968
                i told him i have both jumper harnesses the motor harness that converts dpfi to mpfi obd1 plug and play then a wire plugs into the ecu jumper harness and vtec is already wired and everything all he has to do is instal the wire harnesses and the car will start hit me up if you want them
