Ok CTV, I got an 95 EX coupe with a z6 swap(vtec).. and i want to put it in a 1999 DX coupe (non vtec) .. now what i want to know, is what exactly do i need to put the Z6 swap into the EK shell fully running and everything... im not to sure as to the ECU, Harness, and mounts .. so if any of you out there has info on this, it would be very helpful .. please every detail possible ,, thanx
_Mini Me Swap Help ??D16Z6>D16Y7
Originally posted by JDM8o9 View PostOk CTV, I got an 95 EX coupe with a z6 swap(vtec).. and i want to put it in a 1999 DX coupe (non vtec) .. now what i want to know, is what exactly do i need to put the Z6 swap into the EK shell fully running and everything... im not to sure as to the ECU, Harness, and mounts .. so if any of you out there has info on this, it would be very helpful .. please every detail possible ,, thanxOriginally posted by BurnAll4S4white people suck
Originally posted by astroboy View Postbuy an obd2-obd1 harness adapter for the ecu and dizzy. Put engine in, hook up adapters and p28, and pray. You may have to do some re-wiring for the iacv but I am not positive. You will also have to run 3 wires for vtec (ground, solenoid power, and signal to the ecu).*S14 Kouki *
Originally posted by JohnnyGSRt View PostObd2b ex wiring harness or a si harness... use a p28 with a jumper harness.. Mount r the same etc.. Y7 headgasket upgrade the throttle body to a y8 one... lmk will get into detail
just get 99-00 si wiring harness it'll be plug and play and use jumper harness. or use obd2 alt dizzy injectors ect.. and youll be all set!Need your car detailed? Pm me!
Okay I understood mini me meaning vtec head mated to a non vtec block mounts r the same ect use ur dizzy, alternator and injectors frm the y7 as for the ecu jumper hharness with a obd1 p28 if you use ur stock harness wire VTAKKKKKKK.... and ur set or make it easier and buy a si harness......TURBO 2001 IS300
