Need help with my 2000 ex
  • Need help with my 2000 ex
    I got a 2000 Civic EX it has a p1298 Trouble Code and i have no idea how to fix it. If i know what to do i can do the work. I need my car fixed i miss driving the damn thing
    1. Check engine light is on. Trouble codes P0500, P0135, P0141 and P1298. Fuse #15, the 7.5-amp fuse, was blown and will blow intermittently....
    2000 Honda Civic DX 1.6L *
    Test Details... Confirmed Fix Details...
    Tests/Procedures: 1. Check the wire harness under the intake manifold. The wire harness by the brace, or bottom of the intake manifold, will rub and short out the Black/Yellow wire and cause the fuse to blow and set a...
    Confirmed Fix - Similar Vehicle Match 3 Confirmed fixes
    * Bypass Solenoid
    * Fuse
    * Harness
    2 - Wire Harness
    1 - Exhaust Manifold
    Rocking Slammed Sedan EG8
    I <3 Honda
      damn nigga u know ur shit^^^
        yo d u got any more info on that Joseeg9
          Its a Honda Service Bulletin. Tape & put Wire Loom on the Dummy Connector Harness where it contacts the bottom of the Intake Mani. Then check & replace the #15 Fuse
