15b block with a z6 head ok it run and drive but 1st is good then bog in the rest of the gears i heard you need a y8 cam gear is this true...?
Mini me timing
Originally posted by CTgoldhatch View Postno it is the key way location you need to make up with a half of a tooth and you cant make up a half of a tooth with a belt, the y8 key way is off set half a tooth so it makes up for the needed half of tooth.,
