im looking to build a y8 i already have a built y8 and im looking to boost with like 10psi or so, im looking for 180whp, i heard all i need is rods and pistons, and was wonderin whats a good set to use, someone said i can use ls rods but dont know if i should or what hp theyre able to make...any suggestions
buildin a y8 block
Originally posted by spooncb7 View PostVitara G16 Low Compression Pin Floating Piston Set 8.5:1.....are these good? says they can hold 16-20 pounds i only want 10-12...also you think i should replace all rods and main bearings with oem honda ones?
